Brake Problem - Long Pedal Travel
If it is a caliper hanging up, or a warped rotor, it probably won't give you a code (?) New pads and rotors is probably a good place to start, and when you put them in, give everything a good cleaning, especially where the calipers move in and out.
looks like we are talking about 2 separate problems here, My reply was for Andrew0
If the caliper does not slide on the mount, the piston will be forced to move farther and use up more brake pedal, plus a warped rotor could move the pistons farther in when not applied, also causing a low pedal. Try using a screwdriver to force the pistons farther in the calipers, then step on the pedal.
