Brake Problem - Long Pedal Travel
Old Jul 27, 2015 | 04:42 AM
jimvw57's Avatar
If it is a caliper hanging up, or a warped rotor, it probably won't give you a code (?) New pads and rotors is probably a good place to start, and when you put them in, give everything a good cleaning, especially where the calipers move in and out.
looks like we are talking about 2 separate problems here, My reply was for Andrew0
Old Jul 27, 2015 | 06:10 AM
drowssap's Avatar
i would be looking for a defective master or booster or leak nothing else in the system could effect the pedal height. a frozen caliper or a bad rotor will not effect the pedal height
Old Jul 27, 2015 | 09:02 PM
jimvw57's Avatar
If the caliper does not slide on the mount, the piston will be forced to move farther and use up more brake pedal, plus a warped rotor could move the pistons farther in when not applied, also causing a low pedal. Try using a screwdriver to force the pistons farther in the calipers, then step on the pedal.
Old Jul 27, 2015 | 09:19 PM
Kenso's Avatar
Mine used to do this, I got in the habit of giving it a quick double pump to avoid the low pedal, drove me nuts. I bled the system extensively via a scan tool (nanocom) and the ABS modulator and that cured the issue on my truck.
Old Jul 28, 2015 | 05:29 AM
drowssap's Avatar
ive had several frozen calipers on my d2's never had it change the pedal height
Old Jul 28, 2015 | 08:48 PM
jimvw57's Avatar
Guess you have seen it all. Good Luck!
Old Jul 29, 2015 | 01:53 PM
RandyH1221GJ's Avatar
Based on our schedules, it will likely be a couple of weeks before I get a chance to get back into this. I'll definitely come back with the final fix when I eventually get there. Thanks for all the suggestions offered so far.
Old Jul 30, 2015 | 09:37 AM
fikus555's Avatar
Problem fixed!after changing the vacuum booster,pumped the brakes,start from rear passenger side,after rear drive side,front passenger,front driver,now brakes like new :-)
Old Jul 30, 2015 | 09:38 AM
drowssap's Avatar
great; glad you found the problem without spending to much time and money
Old Jul 30, 2015 | 09:46 AM
fikus555's Avatar
this is the screw to pump,after pumping keep leg on a pedal before closing the screw so it will not suck air back(you need 2 people :-)
