brakes
RE: brakes
Check out these Brake Kits at www.eurotekapg.com They use PBR pads and Brembo or Brake Engineering rotors. In the kit they include a small bottle of a anti-squeal liquid that you paint the friction material surface with -- let it dry for 15 minutes-- and then install the pads. I seems to work great for the people who use it, I am going to use them next time.
I'd stay away from Pads from Mintex-- as they almost always squeak when applying pedalat slow speed.
RE: brakes
I bought a set off ebay from R1. I love them. 20k miles on them and the rotors stilllook brand new and the braking is significantly better.I couldn't be more pleased.
In fact, they messed up order and sent me TWO of everything so I have a complete NEW set of 4 rotors and pads and even a better price than Ebay, and less than 1/2 the price of the kit identified in the prior post. Send me an email if interested.
Oops...just noticed...yours is a 2001. Mine is an 2004 so I am not 100% sure of the fit. You can check throught R1 tho to be sure.
RE: brakes
He guys I just found out today that I also need brakes, all around. javascript:void(AddText('[:@]'))
99.9% of my driving in on-road (occassionally spritedjavascript:void(AddText(''))).
The land rover service rep balked at me when I said I was going to order my parts and have them do the install. They told me that they have to be Land Rover parts or the 3 amigos will be on constantly. Is this true?
RE: brakes
RE: brakes
What is your opinion on Cross Drilled or Drilled and Slotted rotors?
I like the look of them but if you and Disco Mike say they are not good for Disco II's, then I will go with your suggestion, ok?
Also given my driving type what kind of shocks do you suggest? I would like to get Bilsteins because I can get the shocks and the steering stabilizer as a set, what do you think?
Please Respond
Please Respond
