Brakes Feel "Flat"
Brakes Feel "Flat"
Changed my pads and rotors about 4 months ago and bled the brakes at that time and everything was good to go. Now the brakes feel "flat" , not really feeling good stopping power unless I give it a quick pump, then the good feel is there. Does this sound like air in lines?
Air in the lines generally gives more of a mushy pedal than a flat, no grip feeling. You may want to try to bed the pads in again. You should be getting better stopping power out of the brakes than when first installed at this point, not less.
Instead of the usual series of stops you can hit the freeway get it up to 60 or so and apply the brakes with the gas to the floor until you start smelling brake then let off and drive for about 10-15 minutes -without touching the brakes to let them cool then turn around an do it again. If the rotors have a bluish color to them when you get home you got it done.
I was thinking that because the passenger rear caliper didnt look so hot when I did the brakes, it was the only one that was rusted?? So I will check that first, but strange after a pump they feel great.
air in the lines maybe? i might try bleeding again.
