Brakes Feel "Flat"
Old Jul 31, 2009 | 02:18 PM
brooksa's Avatar
Default Brakes Feel "Flat"
Changed my pads and rotors about 4 months ago and bled the brakes at that time and everything was good to go. Now the brakes feel "flat" , not really feeling good stopping power unless I give it a quick pump, then the good feel is there. Does this sound like air in lines?
Old Jul 31, 2009 | 03:28 PM
malmberg's Avatar
When was the last time you flushed the brake fluid? Have you replaced the factory rubber lines with stainless steel? Both of these will give a better feeling pedal.
Old Jul 31, 2009 | 03:41 PM
brooksa's Avatar
Flushed about 4 months ago, and still factory lines.
Old Aug 1, 2009 | 10:39 AM
brooksa's Avatar
bump, anyone Bueller??
Old Aug 1, 2009 | 12:31 PM
hazletbassist89's Avatar
I would try flushing again just in case.
Old Aug 1, 2009 | 01:42 PM
whatmeworry?'s Avatar
Air in the lines generally gives more of a mushy pedal than a flat, no grip feeling. You may want to try to bed the pads in again. You should be getting better stopping power out of the brakes than when first installed at this point, not less.
Instead of the usual series of stops you can hit the freeway get it up to 60 or so and apply the brakes with the gas to the floor until you start smelling brake then let off and drive for about 10-15 minutes -without touching the brakes to let them cool then turn around an do it again. If the rotors have a bluish color to them when you get home you got it done.
Old Aug 1, 2009 | 04:07 PM
oljohnboy's Avatar
a jammed caliper can cause the flat feeling cause it wont move. you might want to make sure all the calipers are engaging. how to do that, i dont know other that removing each wheel and pads, then pump and make sure that they are moving.
Old Aug 1, 2009 | 05:52 PM
brooksa's Avatar
I was thinking that because the passenger rear caliper didnt look so hot when I did the brakes, it was the only one that was rusted?? So I will check that first, but strange after a pump they feel great.
Old Aug 1, 2009 | 07:04 PM
DavidG's Avatar
Sounds like normal rover brakes to me. Every Disco I've ever driven (only 4 or 5) has been exactly the same, very dead but great after one pump.
Old Aug 1, 2009 | 11:48 PM
oljohnboy's Avatar
I dont know about that, i did test drive a rover that the brakes felt unresponsive and flat, in fact i passed the road i wanted to turn on! mine are great. the pedal is responsive and i put new pads all around, it wont stop like a honda, but the pedal feels right.
air in the lines maybe? i might try bleeding again.
