Which brand of gas are you guys using? Is shell a good choice for our trucks?
Ive been doing alot of research on gas brands and Im thinking about switching over from Gulf premium fuel to Shell premium fuel. Any thoughts. Some research suggest all gas is the same, other sources claim that Shell and Exxon were tested as having the highest level of added additives in the fuel which is supposedly good for engines. Ive also read that Shell had a couple problems a couple years ago with bad gas wrecking havoc on cars immediately after fill up. Also read that Shell is responsible for oil spill cover ups in Nigeria. The commercials for Shell gas seem to imply that the company cares about the environment and that their gas is of high quality, and I really like how clean and modern their gas stations look around here.
Im picky about my gas and I always use the same brand of gas which for the last couple years has been Gulf.
1. Any gas from these stations are fine.
Top Tier Gasoline
2.If you are going base your oil company support on their respective environmental morality, buy a bicycle.
Top Tier Gasoline
In my area a big barge comes into the port with all the base gasoline stock. Additives for different companies are mixed in and trucks sent to those stations. The ECU is doing the math and in some models adjusting the timing on the fly for each cylinder. So you seldom get a fuel knock. At least in some areas it would be difficult to see the difference from one brand to another.
![Big Grin](https://landroverforums.com/forum/images/smilies/lxvR5hR.png)
On that note, I live in Washington State, all gas stations are required to sell gasoline with certain percentage Ethanol. Most are around 10%, there's a few gas stations willing to sell Ethanol Free gasoline and pay the fines, but it's well over $4/Gallon.
We should make the tree-hugging politicians pay for the rebuilds on our gunked up Rover V8's due to all the crap ethanol we're forced to burn.
I've been using shell V-Power for about 6 years. When unable to find Shell I use Conaco. I heard from a person at work whose husband drives fuel trucks for the last 15 years. That all the base gas comes from the same refinery. Here in Denver I think it is right off of 274. Then shell probably adds their V-Power magic.
