Break pedal to the Floor!!!
Old Aug 31, 2011 | 07:54 AM
samaro71's Avatar
Default Break pedal to the Floor!!!
This morning my break pedal went right to the floor. I checked my fluid level everything was good. Where is the vacuum line located on the booster? And can I replace the master cylinder myself? I'm pretty handing with cars just never did one before. Can anyone give me directions on replacing it?
Old Aug 31, 2011 | 08:38 AM
buick215's Avatar
It might be your brake booster and not your master cylinder.
Old Aug 31, 2011 | 08:43 AM
Don't guess, it will only cost you money. Where is your fluid level, when was the fluid last changed, have you checked all your wheels for fluid leaks.
The booster hose is right on the booster and is not the problem.
Old Aug 31, 2011 | 12:07 PM
samaro71's Avatar
Had a front brake hose replaced about 2 months ago. Not sure if they flushed the system and if they did not sure if they used DOT 3 or 4. Have not detected any leaks at the wheels. Truck was fine yesterday then right to the floor today.
Old Aug 31, 2011 | 12:13 PM
sloan74's Avatar
How much fluid is in your reservoir?
Old Aug 31, 2011 | 12:23 PM
samaro71's Avatar
Fluid level is dead on. Between the min and max level.
Old Aug 31, 2011 | 02:20 PM
What happens if you pump the pedal 2 times? If nothing, it is a failed master cylinder.
Old Sep 1, 2011 | 12:08 PM
samaro71's Avatar
if i pump the pedal with the car running, nothing happens, if i pump it with the truck off it does firm up quite a bit. Not sure if it matters if the truck is running or not.
Andytats
Mar 27, 2022 01:40 AM
deepski@live.com
Jun 26, 2016 06:25 PM
Tony Crosland
Feb 27, 2013 03:45 PM
Miss Rover
Jan 29, 2013 11:24 AM
LANDZUII
Jul 19, 2009 02:04 PM
