Breaking in rebuilt engine
Hi guys, I am about to start my rebuild engine for the first time and I am nervous about using the right break in oil and procedure. I will be using a non-detergent 30w oil (as the one in the pic below) for 500 miles, with a drain and change of filter at the 20 miles and after that switching to rotella conventional. To prime the system I was thinking about disconnecting the fuel pump and cranking the engine. After firing it up I was thinking about taking it to 2500 rpms and keep it there for 20-25 min and then taking it for a drive.
I would appreciate any suggestions or tips given.
Thanks.
Thanks.
CollieRover (01-10-2020)
The following 2 users liked this post by Sixpack577:
Bal D Correa (01-10-2020),
No Doubt (01-10-2020)
After 20 min at 2k rpm, I would change the oil then.
If you packed the oil pump and there's assembly lube on the cam and all the bearings, I wouldn't disconnect the fuel pump.
I would have someone watching the coolant level while you hold the 2k for 20min for the break in too.
Bal D Correa (01-11-2020)
Electriduct 1" Split Wire Loom Tubing Polyethylene Flexible Conduit (1 Inch ID) - Blue - 10 Feet
Electriduct 3/4" Split Wire Loom Tubing Polyethylene Flexible Conduit (0.75 Inch OD) - 10 Feet - Blue
Richard Gallant (01-10-2020)
You have exhaust wrap insulation on your headers. I tried that on my rebuild and had to shut down my motor in less than 1 minute because my cats couldn't handle the heat and started glowing orange.
I had to replace both of those cats within 2,000 miles after that stunt, so... you can learn proactively from my mistake here!
As for oil and break-in, you want actual dino oil, not synthetic.
Engine break-in differs if you have a new cam or not.
First oil change should be early. Remember, you cross-hatched your cylinder liners and have new piston rings... they are going to be shedding metal as they adapt to each other (cross-hatching wears per ring size)... so your first oil change is for certain going to pull out the metal from that part-matching.
ALWAYS have someone away from your vehicle, but where they can see your undercarriage while you are breaking in your motor. They should be looking for gasoline leaks, p/s leaks, oil leaks, fire, or exhaust overheating that starts glowing.
Large, spare fire extinguisher handy is recommended.
The following 2 users liked this post by No Doubt:
Bal D Correa (01-11-2020),
Sixpack577 (01-11-2020)
