Breather question
Old Feb 13, 2021 | 06:37 PM
Black.Rhino's Avatar
Default Breather question
I have a common ARB compressor issue. Diff oil making it's way up the air line and out the solenoid. I have read to try blowing the breather line out. Some claim If it's clogged it'll send the oil up towards the solenoid. This is the first simple fix. I understand inside the diff an o ring can go bad also allowing oil to bleed by and up the air line.
I'm attaching a pic of the breather point of attachment at the front axle. I tried to pry it out of the axle but since I don't understand the mechanics stopped after I chipped a plastic collar. Any recommendations for getting this end off so I can blow air through the line?
Working it simple to complex.
TIA
Hugh
Old Feb 13, 2021 | 07:34 PM
The Deputy's Avatar
Clean the red connector area, push red ring down, then pull black tube out. It's a compression type fitting.
Old Feb 13, 2021 | 09:21 PM
Thanks for the info.
RA021226
Sep 15, 2019 09:19 PM
mtrdrms
Jan 1, 2013 06:02 PM
grandkodiak
Mar 10, 2011 08:11 PM
aemnky606
May 28, 2010 06:40 PM
timbo
Feb 14, 2007 11:10 AM
