Bright tail lamp ?!?!
Old Oct 22, 2010 | 07:44 PM
jonw118's Avatar
5th Gear
Default Bright tail lamp ?!?!
Hi there-
Recently my rear left brake light burned out.
I replaced the bulb and now the light is on bright (as if the brake was being pressed when it's not). To verify I didn't use the wrong bulb, I took the bulb from the right brake light... and it illuminates bright as well when put into the left one.
Does anyone have any thought as to why it brightens like the brakes are being pressed?
Thanks!
Old Oct 22, 2010 | 08:45 PM
Disconoobie's Avatar
Is your rear fog light button depressed?
Old Oct 22, 2010 | 09:08 PM
jonw118's Avatar
5th Gear
I've tried it with the rear fogs on and off. No difference.
Old Oct 22, 2010 | 09:28 PM
tweakrover's Avatar
if its a dual filliment bulb it could be in backwards, the pegs on the sides are different hights to prevent it going in wrong, but sometimes you can work it in there backwards.
jfall
Oct 5, 2013 11:19 AM
Peter Van Slyke
Sep 3, 2013 07:39 AM
DiscoRover007
Aug 26, 2012 10:48 AM
hleo1
Jul 17, 2008 06:39 PM
bksy1
Freelander
May 23, 2005 01:18 PM
