broke a bolt in the trans pan...
Old Mar 24, 2014 | 02:44 PM
jamestfl's Avatar
Default broke a bolt in the trans pan...
I was changing out the ATF and gasket this wknd and broke one of those little trans pan bolts up in the housing. I don't have any extractor bits that small. suggestions on getting the broken piece out?
Old Mar 24, 2014 | 04:50 PM
ralphobell's Avatar
It is very light weight bolt. I would try just drilling with a bit and then stick a sheet metal screw in it. More than likely it will twist right out. It's just aluminum case and very week bolts.
I did the same on mine and ran and got an extractor at hardware store. Took longer to go to the store then to drill and remove it.
Old Mar 24, 2014 | 10:45 PM
tuercas viejas's Avatar
This sounds like you got too rambunctious as its only a 6mm bolt!
Suggest you go to Grainger and purchase a cobalt L/H drill bit say in 1/8th (3 mm).
Carefully centre pop the broken bolt stub and with the left hand drill try to drill the shank. If you merely broke it off the drill might and I emphasis might, grab the work piece and back it out.
(Got lucky with a Volvo S80 12mm head bolt last week the same way)
If you crossed the bolt in the threads because you didn't align the pan clamps properly and you forced it then you may have to drill the whole piece out and insert a helicoil. (6 x 0.8 mm)
If you are careful you can just get the enough meat in the transmission casting to take the helicoil..
Now remember if the parts store doesn't have 6 x 0.8 you can always elect for 6x1.00 mm but do use a new allen bolt of the same thread pitch.
Best of luck and do use protective eye wear if attempting this!
T/V
Old Mar 25, 2014 | 10:57 AM
pinkytoe69's Avatar
I too broke a bolt head off when doing my filter.
I also could not get an extractor small enough to grab the stud.
I ended up bending the stud to about a 45* angle, then grabbing it with needle nose vice grips (along the "horizontal" plane, so to speak). A few back n' forths and it should break loose. At that point, clip the vice grip so it points straight up the stud and unscrew.
Old Mar 25, 2014 | 12:58 PM
jamestfl's Avatar
thanks guys. seein' as how I was pretty miserable under there, I didn't spend much time having a good look at the break, but I'll get back under there and see about the needle-nose, back-and-forth method.
Old Mar 26, 2014 | 09:36 PM
jfall's Avatar
If there is a stub of a bolt left - use needle nose to just twist it out.
Will probably come out with not much force needed.
Old Mar 26, 2014 | 09:37 PM
jfall's Avatar
But if the pan is not leaking - maybe leave it alone.
Old Mar 26, 2014 | 11:07 PM
pinkytoe69's Avatar
yeah, I forgot to add that mine was rusted tight.
I broke one of the fastener things trying to get the pan off with the broken bolt. After that happened, I got the pan off and had about 2" or so of stud remaining.
I got the replacement stud and fastener from Rovers North IIRC.
Old Mar 27, 2014 | 10:36 AM
drowssap's Avatar
did it break going in or coming out? makes a difference
Old Mar 27, 2014 | 10:41 AM
pinkytoe69's Avatar
Coming out.
