broke off inlet manifold adapter help?
I broke off the plastic inlet manifold adapter that connects the hose to the intake manifold. The part that screws into the manifold is still broke off in the manifold. There is nothing sticking out to grab on to to remove it. Any ideas on how to remove the broke off piece from the intake manifold?
Do you have a set of these 14P Screw Bolt Nut Extractor Extractors Broken Easy Out Free Shipping | eBay and is the hole big enough to put the extractor into it? You can use a small socket to drive it anti clockwise if you cannot fit a tap wrench into the space.
Are you talking about this part Intake Manifold Brake Servo Vacuum (Genuine Part # LZN100220L) - Land Rover hydraulics from Atlantic British ?
If so, I just replaced this also and I did the following.
I removed the intake tube from the throttle body, used a pair of vise grips to hold the throttle full open, then I got a long extension and carefully hammered it out through the throttle body.
JUKE179r (09-18-2019)
I end up 'losing it' and using the 'Irish screwdriver' on everything or anything - (a 4lb lump hammer)
autopia
07-30-2010 11:12 AM
roverdude09
10-11-2009 11:36 PM
Landys4ever
08-10-2009 01:06 PM
matthiasm
05-07-2007 04:43 PM
