broke off inlet manifold adapter help?
Old Feb 23, 2014 | 06:19 PM
aftermath431's Avatar
Default broke off inlet manifold adapter help?
I broke off the plastic inlet manifold adapter that connects the hose to the intake manifold. The part that screws into the manifold is still broke off in the manifold. There is nothing sticking out to grab on to to remove it. Any ideas on how to remove the broke off piece from the intake manifold?
Old Feb 23, 2014 | 06:45 PM
OffroadFrance's Avatar
Do you have a set of these 14P Screw Bolt Nut Extractor Extractors Broken Easy Out Free Shipping | eBay and is the hole big enough to put the extractor into it? You can use a small socket to drive it anti clockwise if you cannot fit a tap wrench into the space.
Old Feb 23, 2014 | 08:13 PM
I don't have one. guess i'm going to have to get one. and hopefully try to get it out tomorrow.
Old Feb 23, 2014 | 09:06 PM
Jared9220's Avatar
Are you talking about this part Intake Manifold Brake Servo Vacuum (Genuine Part # LZN100220L) - Land Rover hydraulics from Atlantic British ?
If so, I just replaced this also and I did the following.
I removed the intake tube from the throttle body, used a pair of vise grips to hold the throttle full open, then I got a long extension and carefully hammered it out through the throttle body.
Old Feb 24, 2014 | 10:50 AM
No it's the one right next to it. I couldn't use a extractor because I tore the hell out of it trying to get it out. but I final got it and put a brass fitting in there instead of the cheap plastic one.
Old Feb 24, 2014 | 03:56 PM
Good one - sorted. I replaced the cr*p plastic filler plugs in the diffs/axles with brass plugs because I could see the same happening there one day and I have a very, very short fuse when things start going wrong.
I end up 'losing it' and using the 'Irish screwdriver' on everything or anything - (a 4lb lump hammer)
rtonder
Freelander
Dec 4, 2010 11:10 PM
autopia
Jul 30, 2010 11:12 AM
roverdude09
Oct 11, 2009 11:36 PM
matthiasm
May 7, 2007 04:43 PM
