Broken Engine Mounts
Old Mar 11, 2019 | 10:40 AM
Lisa Bunch's Avatar
Not the best write-up in the world, but at least it gives you the basic idea.
> https://discoii.wordpress.com/2012/0...engine-mounts/
Like Motorhead1 said, removing the lower studs will allow removal without jacking the engine up as much. I should think about this, and exchanging studs on the new ones for shorter ones?
Old Mar 11, 2019 | 11:52 AM
Motorhead1's Avatar
I wouldn't worry about changing to a shorter stud length. I've had a 50% fail rate when trying to remove the old stud out of the broken motor mount. They can break. I like to anti-seize the treads on the new ones.
Old Mar 18, 2019 | 10:12 AM
Motorhead1's Avatar
Originally Posted by JUKE179r
For the V8 engine mounts may I suggest the 300 TDI #NTC9416 w/ M10 nuts.
It fits our V8s and is cheaper in price.
This will fit our Disco 2's? Are they any stronger than the OEM disco 2 mount? I have one AGAIN that is cracked out pretty good.
https://www.amazon.com/BEARMACH-Engine-Mounting-Part-NTC9416/dp/B07KMP9DKQ/ref=sr_1_fkmr0_1?keywords=motor+mount+ntc9416&qid=1552921522&s=gateway&sr=8-1-fkmr0 https://www.amazon.com/BEARMACH-Engine-Mounting-Part-NTC9416/dp/B07KMP9DKQ/ref=sr_1_fkmr0_1?keywords=motor+mount+ntc9416&qid=1552921522&s=gateway&sr=8-1-fkmr0
Old Mar 18, 2019 | 11:53 AM
Motorhead1's Avatar
Well Ebay actually has great prices on disco 2 mounts, I'll just go that route again.
Old Mar 18, 2019 | 03:23 PM
Lisa Bunch's Avatar
Partsgeek has them for $16.58 ea, but not free shipping, so ebay is probably cheaper. Not many makers out there for these.
Old Mar 18, 2019 | 04:06 PM
Motorhead1's Avatar
I couldn't even find them on Rockauto
Old Mar 18, 2019 | 06:50 PM
Lisa Bunch's Avatar
Nope, they don"t sell them. I think Summit does, I ordered an ATV battery and some wire loom to get free freight, and it came that Monday. I get overnight from them because they have a warehouse in Las Vegas. Good to know if you are in a hurry, if your order is under $100 the freight is usually only $9,99. Cheap overnight!
Old Mar 18, 2019 | 07:13 PM
OverRover's Avatar
Grab a pair of mounts from Lucky8
> https://www.ebay.com/itm/LAND-ROVER-...MAAOSwB09YLpiu
Old Mar 19, 2019 | 01:21 AM
JUKE179r's Avatar
I think Lucky8 has free shipping for forum members on their own website (not eBay) but you have to tell them.
Old Mar 19, 2019 | 10:54 AM
Motorhead1's Avatar
I bought the Lucky8 set on Ebay with free shipping. I think I'll replace them both and keep the good used one as a spare in the rig.
