Broken header to y pipe studs... FML
While removing my y pipe to swap in a CDL transfer case I've managed to break almost every stud on the headers to y pipe connection. I'm thinking I might have to pull the headers, drill out the old studs, tap the hole, and install some new exhaust studs. I don't really want to pull the headers though as I'm sure I will break more studs. do I have any options for a fix without removing the headers?
Edit: did some research and realized that the studs are not welded on but screwed in . New studs are ordered and sadly 4x4 trip with the boys this weekend is canceled.
New manifolds can be found but are $400 each. used ones can be found under $100, but might have the same scenario.
Pull the headers. get correct hardened shorty impact 12pt with flex joint. If you can't remove old studs, get a set of used BUT LOOK CLOSELY at the pics before you buy. Look for good threads on studs and not completely rusted thinned stud shafts. Why? so that you can remove the old studs and put in correct size stainless studs. I did a write up on this somewhere in 'XRAD'S disco 2' thread....
Richard Gallant (07-30-2021)
mr4x4
03-03-2016 10:26 PM
bosshogt
11-27-2011 04:00 PM
