Broken Side Turn Marker Clips
How many of you have this issue with your side turn markers? The clips break and the indicators fall out all the time. Any ideas to get them to stay better without glueing them in or replacing them? Or is it just cheaper and less hassle for another 10 years to replace them with some replacements, possibly non-OEM cheapies? See, I read about a university study that left a car out on the street for a few days, then knocked off a side mirror, then watched society basically take out their frustration on this poor vehicle that they assumed someone didn’t care about until it was completely destroyed. Pretty amazing what people do. I’m glad I don’t live in a city, but this story still sticks with me and I try to make sure nothing like that happens to me The smoky ones look cool, but they’re $45 (not sure if that’s for a pair) and if that would look out of place on a black DII with the rest of the stock amber lights.
$45 oem on Atlantic british - not sure if that’s for a pair (doubtfully)
+1 the 'hot glue' type fix. I fixed the right side that had fallen out (broken clip) using a little bit of clear silicone adhesive. I don't see hot glue (or silicone adhesive) pulling paint off unless maybe you use a high temp / high strength glue stick. There are different types of glue sticks, but generally you find the same type most places. To find high heat you usually have to go out of your way to look for it, at least where I live.
I can't vouch for all types of silicone adhesive, but this product works extremely well for this type of 'fix':
https://shop.wurth.ca/sealants-o-rin...-mL/892.56024/
Might be hard to get as a consumer though, I used to have access to the product from the business I worked for.
The reason I chose to use this is because its waterproof and it's temperature range is well outside the temperatures the light will be exposed to. I am not sure hot glue possesses the same qualities. I probably applied it about 2 years ago and haven't had to touch it since.
