burned out headlight switch?
Old May 22, 2009 | 09:20 PM
99LRDisc's Avatar
Default burned out headlight switch?
Checked all applicable fuses and then some. headlight work, no instrument lights and no parking lamps no door signal warning for headlamps remaining on. Started yesterday, would sometimes not work when i switched them on, but if i kept turning on and off sometimes it would finally come on. now nothing works. opened steering column and wiggled some wires if maybe loose. brakes work, turn signals work, high beams work, hazards work, rear fog lamps work (using them now as tail lights)
if you need more information as to problem, ask, i'll try to answer.
Old May 22, 2009 | 09:30 PM
AK Rover's Avatar
D1 or D2? How many miles?
Old May 22, 2009 | 09:36 PM
99LRDisc's Avatar
D1 131000 on body
Old May 22, 2009 | 09:37 PM
jeffzx9r's Avatar
(Looks like a D1 in the avatar.) I think D1 headlight switches are pretty sensitive to wattage. Are you running "super duper hi-watt plasma" bulbs or something?
Old May 22, 2009 | 09:39 PM
99LRDisc's Avatar
/lowers head...... uh huh
Old May 22, 2009 | 09:43 PM
AK Rover's Avatar
Try swapping to normal set of headlight bulbs and see if it helps. Did you just swap in the super-duper bulbs? If you want more light pick up an HID conversion kit. More light with half the power draw.
Old May 22, 2009 | 09:45 PM
99LRDisc's Avatar
headlight haven't been touched in a long time. i uped to halogen turn signals and for a while, some of the running lamps, but the switch got hot, so i stopped. i think that was two weeks ago, maybe it finally caught up to me
Old May 22, 2009 | 09:46 PM
99LRDisc's Avatar
i had it smoking for a few seconds when i did that to. within the steering column,
Old May 22, 2009 | 09:47 PM
99LRDisc's Avatar
feel stupid, , but that's my story
Old May 22, 2009 | 09:50 PM
AK Rover's Avatar
Electrical items run on smoke. Once you let the smoke out they generally don't work any more. Sounds like you need a new switch, full of smoke.
