Buying a 03 HSE7 with 140K
Shafts even if rebuilt can have problems if not greased on some kind of schedule, every oil change is good. If you can, pay a pro to eyeball the truck for general things, like slipped sleeve making noise, running hot on a scanner (won't see it until too late on the gauge), warning lights not functioning, etc.
on
There is nothing that can leak oil that is higher the the valve covers.
As for the other things mentioned, do you have fault codes to verify what you think needs to be replaced. The drive shaft, as already mentioned still needs to be inspected and make sure there is 1 grease fitting on each of the 3 front u-joints.
Silver_Slug
05-21-2011 08:36 AM
Silver_Slug
04-21-2011 09:23 PM
jwaldron
12-20-2006 02:03 PM
