Buying 2004 D II
Old Jul 20, 2021 | 07:40 PM
  #21
BenDem's Avatar
Originally Posted by tnrangerover
you’ll have to swap the entire tcase or the full nose cone plus add the shifter for an 02. 99-mid01 had the locker but not the shifter.
Out of those two, the 02 looks like a better buy just off the info provided.
Great thanks! Is there anything in particular that you don't like about the '03? (Just out of curiosity)
Old Jul 20, 2021 | 07:49 PM
  #22
tnrangerover's Avatar
the 03-04 models had the poorest machining of the entire run of rover v8s. The 2002 and earlier blocks are mostly all much better machined. You’ll most likely encounter cracked blocks and slipped sleeves during an overheat events on the 03-04 according to anecdotal evidence on the forums.
the 03-04 looks nicer -IMO- and has more power, but the earlier models were built better. I bought an 03 because it had a 2000 4.6 block from a Range Rover and this better machined. It was confirmed upon tear down to do the headgaskets that it was indeed a very well machine block.
Old Jul 20, 2021 | 07:51 PM
  #23
redwhitekat's Avatar
the 03 had no cdl and has the upgraded headlights
the 02 has the 4.0 engine that is said to be a bit stronger vs the 2003-2004 4.6 litre
Buy the one that has the most service records and better looked after.
Old Jul 20, 2021 | 11:12 PM
  #24
BenDem's Avatar
Thanks guys I will look into it!
Old Jul 21, 2021 | 02:20 AM
  #25
The Deputy's Avatar
Just based off info provided...that 02 is in the correct price range. The 03 is not worth nearly what they are asking, in my opinion and l'm aware things run higher over there. But, to many issues listed and repairs on some of them can be staggering, especially A/C. Plus, that 03 looks like it's been ridden hard and put away wet.
Old Jul 21, 2021 | 11:41 AM
  #26
BenDem's Avatar
Can't seem to reach the '02 seller, for now I am trying to get the service records for the '04 and '03, still thinking about the '04 because it is my favorite color of all time (vienna green) and it has the cdl but for now the '03 has better history (less rust, new front drive shaft, new water pump, new sparkplug wiring, new spark plug and new brakes)
Old Jul 21, 2021 | 11:49 AM
  #27
if your serious into offrading you will want one with cdl the 02 might not have cdl nipple 03 for sure not,
Old Jul 21, 2021 | 11:56 AM
  #28
BenDem's Avatar
Originally Posted by redwhitekat
if your serious into offroading you will want one with cdl the 02 might not have cdl nipple 03 for sure not,
Main goal is to restore it so it can be my new daily driver and take it off road occasionally (not planning on adding any lift kit at the moment so pretty light off roading ahead)
Old Jul 21, 2021 | 01:26 PM
  #29
Ok great that 02 is in Ottawa they sell quick there lots of off-roading there
Old Jul 21, 2021 | 02:24 PM
  #30
BenDem's Avatar
yeah I know I just can't reach the seller for now
