Buying parts advise needed
I'm going to be placing an order for a bunch of parts and was looking for some feedback on a company.
Will be buying my lift and brakes for Lucky8
so no worries there but the rest of the stuff i'm thinking about buying from British of Utah formaly Rover Connection.
Has anybody bought from them
Would like some feedback.
Thanks in advance.
please move if this is not the right place for this post.
so no worries there but the rest of the stuff i'm thinking about buying from British of Utah formaly Rover Connection. Has anybody bought from them
Would like some feedback.Thanks in advance.
I recently ordered from Utah. Very good service. They do not sell the 8mm Magnecor wires anymore. But I will be getting my STIs in the mail today.
Atlantic is also good never had a probolem with them. Sent some items back anf they took it back with no questions.
Rover parts is great for expensive used parts. Ive only ordered from the once and didnt have to talk to them but they were quick and the part was good to go.
Thanks in advance.
As for the other parts, not know ing what you are needing makes it hard to tell you where to buy from. Yes British Parts of Utah is a good place to shop and usually cheaper the A.B.
Ive bought various items from all the vendors listed, and haven't had a bad experience yet. Shop around a bit, as some carry particular items cheaper, and/or run specials that can save you a buck or two...
DRW
DRW
Curious as to what brake pads you will be using, there are better pads then what Justin offers, if you want better stopping, no brake dust, no squeaks and last longer.
From British of Utah
ABS modulator shuttle valve repair kit Trans Filter KitWiper Arm Conversion Kit STI Wire Setrubber coupler drive shaftEX gasket, engine block to manifoldRear wiper BladeWiper Arm, Rearfront brake padsrear brake padsgasket, manfold to catalystclip
From Lucky8
Terrafirma D2 Meduim suspension kit cross drilled and slotted rear brake discscross drilled and slotted front brake discs
Thank for the all the good feedback.
this is the type of brake pads you want, i forget the number but it is the Euro type: Akebono: Aftermarket Products and Services
