hey guys i have a 2000 disco 2 and i need some help with my A/C when i turn it on the clutch will not engage but if i unplug it and put power and ground to it the clutch will engage what do i have to look at to fix this thanx
thanx for the quick reply i put one of the refill kits on it that has a gage and with the ac off it says full on the gage when i put power to the clutch with engin running it says low so should i try and fill it when i put power to the clutch ?
If want change the low pressure switch it is old. But the system should be evac for 20 minutes and refilled with some pag oil. Pressures should be low side 20-35 and high side with aux fan running 180-220 psi
