A/C Blower cycling on/off
Old Aug 13, 2008 | 12:02 AM
nofear's Avatar
Default A/C Blower cycling on/off
My 1998 Discoa/c blower keeps turning off momentarily on speed 4(high).
Jiggling the switch fix's the problem. However the problem has gotten so bad over the last few months I have to jiggle the switch every 30 seconds or shove something aroundthe switch to help it make contact.
I amalways using the fan on speed 4 (high). Speed three does not work at all. The rest of the speeds work but not enough air flow here in California.
I see some similar post on the forum, but no resolutions yet. I'm thinking about either replacing the control panel $190 or resistors/relays. Any suggestions? Thanks
Old Aug 13, 2008 | 09:21 AM
Landzu's Avatar
Default RE: A/C Blower cycling on/off
Its time to get a new switch.
Old Aug 13, 2008 | 09:28 AM
"DITTO"!! Unless your year had separate resistor packs, cause they can also cause your problem.
None of the fan motors are designed to run high speed over long periods, just burns up the works.
starcraft1
Jul 22, 2013 02:10 PM
Speegles
May 8, 2011 06:54 PM
nazdackster
Feb 17, 2010 09:21 PM
99LRDisc
Apr 26, 2009 06:25 PM
allez117
Jan 8, 2009 05:48 PM
