A/C doing it's own thing
Old Jul 24, 2008 | 03:57 PM
DecoyTheDead's Avatar
Default A/C doing it's own thing
So, driving down the road one day, the a/c quit blowing. I have checked the fuses, replaced the relay under the hood, replaced the actual blower motor all to no avail. I measured only about 10Volts coming out of the wire harness to the fan. I am guessing this should be up around 12 to 14. A friend told me to measure the voltage in both fuse boxes and that probably my fuse box has gone out. I went to buy the resistor pack and the dealership told me not to because they had never had to replace one. I hate to keep replacing parts, but living in Texas in July with no a/c is getting old. If you have any suggestions, I would love to know them. Thank you for your time.
Bob
Old Jul 24, 2008 | 06:07 PM
Default RE: A/C doing it's own thing
Sorry, I got nutin'
Old Jul 24, 2008 | 07:04 PM
Have someone run a diagnostic on the control unit and you will find your problem.
Old Jul 24, 2008 | 07:19 PM
Darover's Avatar
Mine stopped working also. and although I had verified that the plug-in under the hood was click shut firmly, I hadn't noticed that one of the wires in the plug-in was not pushed in all the way. Probably had detached from engine vibes, I don't know, but all that was needed was to push this wire as deep as it would go in the plug-in to make contact and voilĂ*!!!! A/C was back. I was lucky enough to find the culprit before starting changing parts.
Claridget
Sep 6, 2007 08:46 AM
juliogrullon
Apr 22, 2007 05:24 AM
Stickestar
Appearance & Camping Set Ups
Dec 13, 2006 03:25 AM
SJUroverproj
Nov 5, 2005 12:13 PM
dbear
Jul 17, 2005 02:21 AM
