A.c.e..????
Hey all, i drive a disco series 2 and am loving it but am having dramas with my a.c.e. The red light keeps flashing, ive had it hooked up to the testbook program and have been told i pretty much need a new everything. My question is is it worth while disconnecting the a.c.e? Has anyone done it? I know it helps with cornering but id rather feel the corner than glide through it anyway, plus ive put new springs and shocks all round and theyre the highest load rating springs possible..... So being a cost factor to fix should i just disconnect it??
I think you were lied to.
I assume that YOU checked the fluid level? Yes? YOU checked it?
Right on the power steering resevoir, remove the cap with the "ACE" on it and top off with regualr old power sterring fluid.
Then if that is well look up Urban Panzer, his truck has ACE and he knows it inside and out.
He had a $30 sensor go bad, that may be your problem too.
The ACE system is pretty reliable.
