A/C Heater Blower Motor Removal, Cleaning, Oiling, Installation
Old 06-12-2013, 06:59 PM
dparham's Avatar
Originally Posted by SuperSport
Is it a relay you can see? I would swap it with another one and see if that fixes it. They are cheap to replace. I've actually opened them up and cleaned the contacts to get them working again.
Other options is when the motor is out, verify if the Brushes and Armature are both ok. If the brushes are too worn, or if they are stuck from gunk, they will not touch the Armature enough to make an electrical connection. Or, the Armatures can be worn enough they don't work anymore.
yeah... Ill check that too.... on my old car.. "British Rover Sterling" the motor just fell apart... it was the brushes... fortunately that part was from a honda... so was super cheap part... That fan made allot of noise... this Disco fan didnt make any real noise... however........ before it cut out... the fan didnt seem like it really blew cold.. not like it did when I bought it at least.... but then when it came back on... it was blowing MUCH harder and I was like NIIICCEE! ... then it stopped for good...
Are these relays just like the other ones on the fuse panel? I have a handful of those lol
  #32
Old 06-12-2013, 07:07 PM
SuperSport's Avatar
I have not looked at the ones you are speaking of, but if the plugs are the same, they likely are. There are also numbers on the side of them, see if the numbers match. If they do, you are good to try it. I haven't yet messed with the relays in the Rover, but in my Jaguar, there were about 15 that were the same, so it was easy to find one to swap with.
  #33
Old 06-12-2013, 07:08 PM
dparham's Avatar
yeah.. all those yellow ones are the same and there are a few of the black ones I have too... Ill check them out when I get home... OH PLEASE OH PLEASE! BE THE FIX FOR MY AC! lol
  #34
Old 06-13-2013, 08:55 AM
dparham's Avatar
Hmmmm i may have found something.... Im getting 14.3v as i think is normal from full battery power... However... When unpluging a hot connector under dash (smelled wet burning plastic before a/c stopped few weeks ago as a reference) well i noticed this... Anyone know what effect this would have? Lol
Fan when jumped directly to battery works great so thats not the issue
Attached Thumbnails A/C Heater Blower Motor Removal, Cleaning, Oiling, Installation-image.jpg
  #35
Old 06-13-2013, 08:58 AM
SuperSport's Avatar
Hmmmm i may have found something.... Im getting 14.3v as i think is normal from full battery power... However... When unpluging a hot connector under dash (smelled wet burning plastic before a/c stopped few weeks ago as a reference) well i noticed this... Anyone know what effect this wouod have? Lol
Likely a loose connection there that caused the heat. When the plastic melted, it caused the connection to get even worse. Clean and tighten (replace plug if necessary), and hopefully all will be well again.
  #36
Old 06-13-2013, 09:00 AM
dparham's Avatar
I may cut off the offending plug and instal an Anderson plug... heck, that means my fuse panel may also be good
  #37
Old 06-13-2013, 09:24 AM
SuperSport's Avatar
Wouldn't THAT be nice. Good luck.
  #38
Old 06-13-2013, 09:51 AM
drowssap's Avatar
yup, a new plug and make sure that wire is fused, with that much heat , the increase in amperage should have tripped a fuse
  #39
Old 06-13-2013, 10:05 AM
dparham's Avatar
yeah.... maybe it was a quick shot of a loose plug and bamo! that makes sense that when i fiddled around there probing for a hot then fan started working... I think possibly a loose fitting sparked... melted the plastic between the hot side coating it and when fiddling around down there inadvertently allowed for it to make contact temporarily but still in a loose state... so as expected.. shorted out again... hmmm dangerous to have little fires under dash! lol maybe its best to replace all connectors with nice Anderson's! lol or equivalent lol Too bad I wasn't enjoying a nice deep mudhole when that happened! haha
  #40
Old 06-13-2013, 11:12 AM
dparham's Avatar
Well here was my problem! A/c blowing hard again!
This is the brown/red - black connection on right side of motor ( not the blue /red connector...
Quick Reply: A/C Heater Blower Motor Removal, Cleaning, Oiling, Installation
