A/C Recharging?
Old Jun 19, 2007 | 04:52 PM
lowill's Avatar
Default A/C Recharging?
Hey guys needed some help on recharging my system. Bought the truck in Oct/06 so I never checked it. Yeah dumb move. All the fuses are good so I figured on starting with the cheapest thing. Thanks
Old Jun 19, 2007 | 05:18 PM
okdiscoguy's Avatar
Default RE: A/C Recharging?
what year, mileage, etc..... do you have rear air?
What do you want to know?
Old Jun 19, 2007 | 06:09 PM
You never start with the "Cheapest Way First" with a/c. Actually sounds like you have no knowledge of the workings of a a/c system and I would suggest you go find a shop and have them look at it.
Mike
Old Jun 20, 2007 | 10:35 AM
lowill's Avatar
Sorry about that its a 98 disco with 100,500 miles. Yes it does. As for knowledge Mike if I knew what to do then why would I post anything? Right. Did a A/C recharge on my toyota echo just wondering if all my truck needed was the R134a.
Old Jun 20, 2007 | 01:48 PM
Landzu's Avatar
Yes R134a is what it takes.
Old Jun 20, 2007 | 05:27 PM
So it is a high miled 96, it should be pumped down remove what little oil is still left in the system, under a vacuum replace the oil then recharge with out blowing your reed valves.
Do you have a pump and a set of guages, if not you are risking damage to the a/c system.
Mike
primey
Apr 19, 2011 08:34 PM
jbgator3
Dec 20, 2010 07:52 AM
