california smog help!
Just out of curiosity, is it completing the other drive cycles? Like evap, SAI, o2 readiness? Can you use your scanner to verify the downstream O2 sensors are giving out correct information? Also, when you are driving around, is it running it open loop or closed loop mode once it is all warmed up?
searching the net probably your best bet, for example:
https://landroverforums.com/forum/di...e-drive-75611/
How was the ECU 'flashed'?
You say you do not have codes. As a side note, I could not get my codes cleared until I used walker O2 sensors. I went through 2 or 3 sets of other brands. Walker UP 350-34462 DOWN 350-34188. What are you using?
Same thing as I posted before. It shouldn't take 200+ miles to complete the drive cycles. I had all of mine complete in less than 50 I would say. Just some various warmup cycles and cruising at 45-50mph and 35-40mph around the country back roads where I live for an hour or so. I'm really curious if his Disco is ever getting to closed loop mode once he gets it running. If it's not, something is definitely wrong with his O2 sensors and/or ECU, although I have a hard time believing that two different ECUs would have the same problem...Again verify that your O2 sensors are working correctly and it is entering closed loop upon warmup. I'm no Bosch ECU specialist at all, but I have a hard time believing it would complete the readiness test before its entered closed loop.
anyone in los angeles know of somewhere to get your car "passed" for smog? im about to pull my hair out dealing with this. ive been trying for almost 2 years to get my cat to reset and it just won't! i had some stereo work done to replace blown speakers and a new head unit put in. and from disconnecting the battery i think that triggers the cat to have to be reset again. so ive tried every driving trick in the book thats supposed to reset it, but nothing works. we've also changed everything possible and the f(&(*& thing will not reset. it doesn't throw codes and everything is perfect so im lost here. im ready to submit and just pay someone off to get this done. any help would be appreciated. thanks fellas!
I bought it and was so hot to buy it I forgot to get the seller to provide a smog cert. In California by law it is the seller's responsibility. I reached out to him and thus far is unresponsible.
TIA
Hugh
Good thread here: https://www.bimmerforums.com/forum/s...ained-smogging D2 ECU is same generation as several of the BMW's (BMW owned LR from 95-04 ish)
Still seems kinda a murky mess.
update on mine guys...i actually got mine to pass! i spent 2+ years and changed out everything possible and this is what actually worked!!!
unbelievable i know. i bought 2 bottles of it bc of the fuel tank size and used as it recommended assuming if it worked at all it would take running through a couple tanks atleast. i finished the first tank and added the second bottle preparing to run through another tank. just for the hell of it i checked it with my reader and i was F(*&^* shocked that it said the cat was ready. i think i sat in the car laughing for about 10 minutes totally miffed how after all the **** i spent cash on and replaced i spent 17$ at walmart on two bottles of that stuff. i took over to the star smog place and it passed with flying colors.
https://www.amazon.com/CRC-05063-Gua...0130131&sr=8-3
I have literally never owned a vehicle that has this kind of issue. I find it interesting that when I reset the DTC's and did drive cycle "d" all 7 monitors came up with the Evap monitor "incomplete". Previously, the evap monitor was complete and just the cat monitor was the hang up. I have done all the drive cycles except A and E. I need to fill the tank back up to at least 3/4 and let it sit and do those last 2. If this doesn't clear I may try your additive solution and if that doesn't work I'll just go the other root and pay someone to pass it. I have a life after all and would like to enjoy it wheeling and camping.
