can i swap slabs ecu??
I second that. I got the 3 Amigos several years after my shuttle valve repair with option B. After verifying my repairs were still good, I checked voltages to the modulator and from the SLABS ECU and compared with a friend's D2. After finding slightly different voltages, I borrowed his SLABS ECU, and no more amigos. I've had his in my D2 for the past 3 months while his is down while he considers doing head gaskets. Mine is a 2000, and his a 2002. Neither with SLS.
I will mention that there is just one wire/pin on the slabs computer for road speed signal, so if your speedo is showing the correct speed and at least one of the computers is showing the correct speed, your slabs is probably fine. I'd be concerned about the wiring or the computer that has incorrect data.
This is how I found what was wrong with mine. I swapped the slabs from my 03 to my 99 and nothing changed... the engine ecu still thought I was going 88mph, but the speedo was dead on and so was the speed from the slabs or the tcm, I don't recall which I could see with the hawkeye. This was causing the engine to never idle properly.
I opened the engine ecu up and it was nasty. I rolled the dice and WASHED the inside of the computer, connectors, chips, and all, under the kitchen faucet with dish soap, and then rinsed it with alcohol and again with distilled water, and let it dry and tried it again. Of course I'm not advising anyone to do that, except at their own risk of damaging something, but I figured I was going to have to buy a new ECU anyway so what the heck.
