Can I take the tow package off an HSE?
Old May 22, 2010 | 07:48 AM
oysterhead's Avatar
Default Can I take the tow package off an HSE?
A local craigslist guy is offering his "extras" of his 04 HSE before trading it in to the dealer....
It seems he has a slot for a reciever hitch, which I dont have.
Would it be simple to remove the "tow package" off his truck and put it on mine?
Thanks, Dustin
Old May 22, 2010 | 08:19 AM
03discoman's Avatar
yes.... his is bolted to the frame...you can unbolt it and install it on yours
Old May 22, 2010 | 08:20 AM
All D2's use the same tow package, so yes you could.
Old May 22, 2010 | 10:51 PM
oysterhead's Avatar
any tricks to the un-bolting/removal process?
Old May 22, 2010 | 11:18 PM
03discoman's Avatar
its pretty easy.... just unbolt it and install on yours....
i dont know the socket sizes, but bring some PB blaster and get his trailer lights also...
Old May 24, 2010 | 03:05 PM
00&04 Disco's Avatar
I took a tow package off of an HSE and put it on my 04 that didnt have one and it bolted right up. I also took the hydraulic step and it mounted right up. There will be four bolts total. I believe the two smaller ones are 12mm on the top bracket and the bolts throught the subframe are like 17/19mm but you will need a wrench and a socket or two wrenches because they have a bolt and nut not just a bolt threaded into the frame. Also make sure sure you do bring a wrench and not two sockets because one side is pretty tight so couldn't get two sockets in there. I will go home and see if I can get the exact sizes for you so you can be prepared.
Old May 25, 2010 | 09:55 AM
oysterhead's Avatar
Great answer. I appreciate your help.
Let me know what you find out.
MiDisco2
May 28, 2014 08:53 PM
96redvettelt4
Feb 22, 2014 11:26 PM
MinneapM635
Jul 5, 2012 12:45 PM
DanR
Dec 21, 2008 07:59 PM
The Champ
Jun 17, 2007 11:06 AM
