Can I wire Brush Guard lights to the factory fog lights?
Old Dec 13, 2014 | 03:37 PM
dparham's Avatar
one more stupid question lol when wiring up the CREE LED lights I have 2 x 18.5w do I still use relay and fuse same as the halogen setup?? Im guessing they have a ballast or something inside lights?
Old Dec 14, 2014 | 08:59 AM
Richard Moss's Avatar
I would but at about 1.5 amp each they're probably OK to be just wired direct from the switch.
is it possible for one switch to trigger 2 relays wired in? that way 1 relay per 2 lights but all 4 would be activated by the same switch.
Yes but it's cheaper and easier to use one heavy duty relay
Old Dec 14, 2014 | 09:24 AM
dparham's Avatar
Yes i think this relay is 40amp its a hella 4RA 700 791 02 that comes with the 700FF 2 light kit
Old Nov 21, 2015 | 04:27 PM
Dani Ezelle's Avatar
I just purchased 2 after market LED off road lights and want to install them on the brush guard and tie it in directly to the fog lights on my 2013 LR4. Is this ok to do?
Old Nov 21, 2015 | 05:47 PM
Alex_M's Avatar
Depends on the lights and how much power they pull. As a general rule, no. you'd really want to wire then up through a relay that is switched on either by the fog lights, high beams (the typical choice), or a seperate switch.
hankeester
Dec 31, 2014 10:54 AM
rosettaquarrier
Feb 3, 2014 08:40 PM
salve7
Oct 27, 2008 04:28 PM
bartrol
Jun 29, 2008 10:18 AM
oneup
Mar 23, 2008 09:19 PM
