Can one person change PS fluid?
So just shoot out ps fluid all in the engine bay? Maybe I'm not following you. Guess I need to buy some more I only have two quarts (bought all of the 60K service stuff even though I did it 19K ago at 60 but It has been almost two years so I'm doing it all again.
Mike I'm out of town from tomorrow morning until Weds but I'll shoot you my number then. Might not be my steering pump but there's a noise when I'm either stopped or moving slowly and turn the wheel a good bit. Had the tires changed yesterday and they said they lubed everything underneath (I'm going to grease the ds again myself Tuesday just to be safe...checked it the last time a shop said they did it and it wasn't done). I changed the brakes/fluid, oil, tran fluid, gear oil, flushed coolant/new t-stat, and plugs today. Took about 7 hours and now my neck is strained but I felt like getting it all done before my drive in the morning.
Can I just knock some of the dust etc off my air filter before the drive? I ordered a filter and new belt but it'll be here sometime next week.
To add switching from T6 to Mobil 1 definitely made a difference in the engine not making as much noise. T6 was the worst oil as far as noise I've ever used and only kept it in for 1500 miles because of that.
I attached a long clear plastic tubing (from home depot) to the bleeding niple, opened the bleeding screw, fieled up the reservoir and started the engine. The tube went into one container and I kept pouring PS fluid into the reservoir. After about 2 quarts, clear and clean fluid was coming out of the bleeding niple. Turned of the engine and ttightened up the bleeding screw. No mess.
What he said.
And if you save your empty washer fluid bottles or gallon oil jugs you can stick the hose into one of them and you are good to go.
If you have a friend (I suggest you find one) they can start the engine while you keep the power steering system full.
Once clean fluid comes out have them turn it off.
Put hose back, top off the system.
This is the best way to flush the power steering system.
You wouldn't just suck out the old brake fluid and mix new with the old, so why do the same with the power steering?
The power steering system only holds like a quart or so, so a empty gal jug is plenty.
Then take your old OIL to be recycled.
