Can Stop The Fan With My Hands
Old 11-29-2017, 08:35 PM
number9's Avatar
Originally Posted by Mr. Tick
Notice any difference
Went through cooling system after purchase of D2 with under 100k miles a bit over 2 years ago. Came here and read of many potential issues prior to purchase and most of my maintenance/replacements just time change/precautionary. Recommendation at the time was to use that fan blade/clutch, like the blade being shrouded for safety if working on the engine when running and more like OEM. No difference noted as original assemble was probably working as advertised. Summer in the city idle in traffic about 195 F max.
Doubt much different performance between Dorman blade and OEM type except one's less expensive.
Old 12-01-2017, 01:43 PM
Sixpack577's Avatar
Here's a side by side picture before I changed it.
Attached Thumbnails Can Stop The Fan With My Hands-20170824_231812.jpg   Can Stop The Fan With My Hands-20170824_231840.jpg
OverRover (12-01-2017)
Old 12-01-2017, 01:46 PM
Sixpack577's Avatar
And you'll need 4 bolts to put the fan on the fan clutch, I forget what size they were.
There are none to swap over from the stock fan either, as stock fan and clutch are one piece.
Mr. Tick's Avatar
So what percent of air would you say this new fan moves in regard to the old one. Like I've heard as much as 40% increased!
Old 12-01-2017, 01:52 PM
Sixpack577's Avatar
I couldn't honestly say.
I replaced it along with alot of other parts...to stop the tick...which I didn't. So now I'm taking the engine out to pin all 8 liners and check /replace the flexplate. Apparently they tick too if they get stress cracks.
Fortunately, my engine didn't run hot to start with.
But, at 13/14 years and 122k miles, for $62, I figured it was good insurance.
The fan fits well in the shroud too, no clearance issues at all. It is a little wider, but a slightly smaller diameter than stock.
Sorry I have no before and after temps. I bought a ScanGage also, but not til after the new fan.
tooltech
03-22-2013 08:39 AM
indasevens
08-20-2012 11:39 AM
jmhoneybird
LR4
02-03-2011 12:48 AM
MJ2
07-27-2009 10:02 PM
Quick Reply: Can Stop The Fan With My Hands
