Can these rusty coils be saved?
Old Jun 9, 2018 | 05:17 PM
TRIARII's Avatar
Default Can these rusty coils be saved?
Id like to swap the suspension system from my parts truck to my driver but man they look like ****! Rusty as all hell. Anyways I contacted a local forge and they quoted me $200 to sandblast and paint 4 coils and 4 shocks. So you guys think these can be saved or too far gone. Suspension is a TerraFirma 3" HD lift installed new in late 2012. They have seen much abuse.......
My daily driver is still running original factory coils and springs mind you 215k and heavily loaded with roof rack, steel bumper, winch, hi-lift and bunch of other ****. Figured Id throw these on until Im ready to upgrade to Old Man Emu.
Old Jun 9, 2018 | 05:18 PM
TRIARII's Avatar
Default pics
Old Jun 9, 2018 | 05:34 PM
springs rust, hit them with some rust stop and a quick shot of paint if it really bothers you. Than put them in. Wouldn't worry about it in the least.
Old Jun 9, 2018 | 05:48 PM
OverRover's Avatar
I would NEVER waste $200 to do ANYTHING to a 6 yr old TF Spring or Shock! Save the money and get a new set when you have the coin.
Until then do as AR said, just clean the old scrap up and move on.
Old Jun 10, 2018 | 06:30 AM
OffroadFrance's Avatar
Hi TRIARR II
Yep, just rust stop them and paint them up. They are hard working high tensile steel so they tend to rust easily.
You need to replace your shock towers soon though or they will be taking a trip through the hood! They make galvanised skeletal type now.
I use these:
Disco 2 Heavy Duty Shock Absorber Turrets - Pair - Galvanised - Paddock Spares
Old Jun 10, 2018 | 09:08 AM
TRIARII's Avatar
Originally Posted by OffroadFrance
Hi TRIARR II
I use these:
No worries about the shock towers because Id be installing these coils/shocks on my rust free truck. I just dont want the rust to spread to my flawless frame plus I want the coils/shocks to look nice. The OME kit Im looking at is around $800 so spending $200 now for a professional sand blasting followed with a epoxy primer and high heat paint seems the way to go. I was just concerned that the rust may have done too much damage to be saved.
Old Jun 10, 2018 | 09:29 AM
OverRover's Avatar
The only thing spending $200 on an old set of worn out springs will prove is .....
…. You Can Try to Polish a TURD!!!
GOOD LUCK
Old Jun 10, 2018 | 11:49 AM
Saturnine's Avatar
My springs are kinda rusty as well, but they are OME's.. I probably should take them out and do the rust stop / paint dealio but.. i'm lazy.
Old Jun 10, 2018 | 02:12 PM
shanechevelle's Avatar
Take some sandpaper to them, primer, then paint.
If I start up my powdercoating booth again...I could blast and powder...for less than $200
Old Jun 10, 2018 | 02:43 PM
Dave03S's Avatar
Wire brush.
