Can you mount a hi jack to a Thule rack
Old Feb 15, 2011 | 09:59 PM
DiscoBenjamin's Avatar
Default Can you mount a hi jack to a Thule rack
I have both the high thule rack in the back and the Thule cross bar rack in the front, can I mount a serious jack up there? Also can one of those high jacks be used to do any work like brake changes and a spring shock kit? If not, what is the most economical option for a jack stand kit that is substantial enough for work on a disco?
Old Feb 16, 2011 | 05:33 AM
hilltoppersx's Avatar
you can use quick fist's to mount it up there if you really wanted, just stick it in the trunk. use the bottle jack to do brake changes and you can use the bottle jack to take the body off the frame to do the springs and shocks.
Old Feb 16, 2011 | 08:28 AM
Bundu's Avatar
Banned
Your questions scare me about that high lift jack, they are deadly in inexperienced hands. They have a nasty habit of slipping their loads and I don't know of anyone that can bench press a disco. Sure they look cool mounted on an expedition rack, but that is where they should stay. If you do not have steel bumpers and/or rock sliders with jack lift points then the high lift jack is not of much use to you. Be careful with that thing. Don't take this wrong, my concern is your safety.
Safety first, if you are working on or under the disco then use jack stands, the bigger the better. Don't work on a vehicle that is supported only by a jack. I have a set of 6 ton stands from HF, they will take the load and give you enough height and their price is fair. Get a 20 ton bottle jack while you are there - mainly for the lift height.
Old Feb 16, 2011 | 09:17 AM
dcarr1971's Avatar
+1 to all of the above.
The high lift jacks are dangerous if you don't know what you're doing. If you really want to carry one, lay it across the floor in the back seat and zip tie it down to the back of the front seat bases to keep it from flopping around. This will keep it out of the way, and protect the jack from the elements.
Old Feb 16, 2011 | 06:46 PM
Can you mount a Hi-Lift to a Thule rack?
Yes, yes you can.
https://landroverforums.com/forum/sh...ad.php?t=33519
Just space your cross bars far enough apart to get a good fit.
LRDisco2HI
Aug 26, 2011 02:10 AM
Torancis_LR
Jun 28, 2010 11:55 PM
unrealtrip
Dec 19, 2007 08:46 AM
dinandan
Jul 4, 2006 10:43 AM
dinandan
Jun 22, 2006 07:22 PM
