Cannot Locate Clunk, Here Are Symptoms.
Old Jun 10, 2010 | 09:16 PM
greg409's Avatar
Originally Posted by Spencerfitch
Is grease in the dust cap a sign of anything?
I'd guess somebody put grease on the stub axle splines on re-assembly, or greased the crap out of the hub bearings.
luck,greg
Old Jun 10, 2010 | 09:23 PM
I too was going to say a flopping around brake pad.
Old Jun 10, 2010 | 09:27 PM
bmw zhp's Avatar
like i said before shock bushings on mine were bad.i too could not recreate the sound by bouncing it.now that i installed a supergas suspension its not clunking in strait line.
shortly after completing the work i noticed the drivers side front wheel had just alittle
play in it do to a bad ball joint went ahead and replaced that as well and have not heard a clunking since.
Old Jun 12, 2010 | 07:43 PM
Spencerfitch's Avatar
it was the radius arm!!
im so happy right now
Old Jun 12, 2010 | 10:03 PM
THANK YOU for reporting back!!
Old Jun 13, 2010 | 11:29 AM
discoklein's Avatar
did you have to replace the bushings in that radius arm only and how did you discover it...?
Old Jun 13, 2010 | 11:57 AM
I just tightened it. It was wear it attached to the Axle I just grabbed it and shook it, and THOUGHT I felt a little play, tightened the rear bolt and it's gone.
Old Jun 13, 2010 | 12:16 PM
Double post.
Old Jun 13, 2010 | 12:17 PM
discoklein's Avatar
sweet, thanks for the quick reply, i have to put my driveshaft back on tomorrow and I will check all nuts and bolts for tightness then...
Old Jul 20, 2019 | 08:30 AM
Rdhilaire's Avatar
Default Clunk
I had a piece of gear in my transfer case and would clunk and bind especially backing up. Changed case and gone.
LADEROUTE
Nov 6, 2012 05:56 PM
LeakyDisco
Jul 27, 2011 10:14 AM
llPANCHOll
Apr 1, 2010 01:29 AM
jasons
Jul 29, 2009 09:59 AM
tom
Nov 12, 2006 01:14 AM
