Can't fill gas tank?
Haven't run into this yet. Not sure what the hold up is. Tank at 1/4. Go-to fill up and the fuel just comes out the nozzle as if it's full. Filler keeps kicking off. Managed to be patient and fill it slowly to get by but 20 minutes for 15 gallons is just annoying. Gas attendant didn't like me either.
Any thoughts?
Any thoughts?
I was about to joke that you should just take it to Oregon and have someone fill it up for you, but then I saw you were from Bend, so my joke was preemptively ruined. It could be a clogged fuel vent hose, there is a forum post on how to replace it here:
https://landroverforums.com/forum/di...nt-hose-41987/
But that looks like a big job, so I would see if it happens at another gas station, maybe there is something peculiar about the D2 filler hose and that pump/station which is causing fuel to splash back and kick out the trigger. Alternatively I have heard of folks pouring fuel injector cleaner down the hose to try and clear gunk out of it.
Good luck!
Good luck!
GoRoll (10-15-2019)
Not saying you don't have something wrong, but old cars are notoriously finicky with modern fuel pumps and can differ from station to station. I have yet to run into a problem with my D2, but I have a 1995 Mercedes and a 1985 Lotus that have both encountered fuel filling issues at different gas stations at different times. At some stations I have to fill my Mercedes at half-speed otherwise the pump cuts off, and there are some stations my Lotus just won't accept fuel from at any speed without it spilling out from the cap after a few seconds.
i'm dealing with this right now myself. my truck suddenly started doing it a couple of tanks ago, after having been fine for as long as i've owned it.
all advice and logic points to it being a blockage in one of the venting lines. so last night i removed the charcoal canister and blew compressed air through each of the lines in turn (with the gas cap off) except for the purge line that goes back to the intake manifold. i could hear the vapour line to the fuel tank bubbling so i'm assuming that something was getting through. i also blew through each of the ports in the charcoal canister itself.
i haven't had a chance to try to fill the tank yet to test for any improvement, but i'm hopeful.
the link posted above is for a d1. the d2 system might be different.
Same thing happens to me, baffling why some pumps do this and most don't.
