cant get caliper guide pin bolts out, please help
What spike said is true take the two big bolts out and lift the whole thing out as a unit. Also, make sure your turning the right way, its easy to get turned around when your looking at bolts backwards and upside down. Most of the time wacking the handle of your socket ratchet with a hammer is good enough to knock it loose or use a breaker bar.
The two bolts that are on the caliper are the only ones you need to remove.
If you stripped the bolt then you used the wrong sized socket.
Mine were 1/2" 12point not 13mm like in your link.
Read above: as I mentioned above if I take off the caliper first then I will have no leverage to hold the caliper still in order to get the guide pins out. and I do not have a bench vice. Already tried liquid wrench (same thing as PB Blaster) and no luck, the bolts are to tight and to corroded. A torch is the only option I have now....
You have to take out the two big bolts, you can reach them with an extension and a breaker bar. Its not easy but, it is no way impossible. Rotate the steering wheel to get the whole assembly in better line. The bolts will be tighter then the slide bolts but, they will come out. I have done this numerous times. You dont need to replace the pins, slide the rubber boot back and clean the pin and re-grease. If the slides are rusty hit them with sandpaper.
I remember when I was doing my brake job a couple mo the ago I had to lift the truck, put a wrench on the bolts, put a jack stand under the wrench, and lower the truck and use the weight of the truck to free up the bolts. It worked great and saved me a lot of time on the other wheels once I figured this method out. If the bolt head is stripped though, use the impact. And a big hammer.
It all comes down to the right tools for the right job; the bolts that hold the caliper to the bracket are 6-point not 12 point 12 mm bolts. You only use a 12 point on a 6 point socket if it has started to round, If not you can be pretty sure that you will round it.
The bolts holding the bracket to the differential housing is a 13mm 12 point socket, these you should not normally have to remove.
You should be able to break the 12mm free with a 24 inch breaker bar and even pressure, not a hammer .yes it is a bitch but my truck lived it life in NH and is now on the sea shore so I know about rusted fasteners.
At this point you have new calipers so you really have nothing to lose by using heat on the old ones, but even heat will not work unless you have socket that fit the bolt head tight, even if you have to drive the socket on there.
You might also want to pick up a can of Sea Foam “Deep Creep”; all penetrating oils are not the same.
