Can't get front driveshaft out
Old Sep 29, 2012 | 10:24 AM
dr. mordo's Avatar
Default Can't get front driveshaft out
I'm attacking the Major Service, and I figured I'd go ahead and replace all the u-joints. I've removed all the nuts and bolts from the front shaft, and the front came loose instantly. But the back is stuck to the fitting on the transfer case. I smacked it a few times with a rubber mallet, but it's pretty stuck.
Any suggestions? Am I missing something?
Old Sep 29, 2012 | 10:33 AM
Racer X's Avatar
Tap it with a steel mallet. You'll need to shock it loose, something you can't do with a rubber mallet or a dead blow hammer.
If that doesn't work, use a penetrating oil. I'm pretty fond of a 50/50 mix of acetone and ATF.
Old Sep 29, 2012 | 10:46 AM
Are you also planning on replacing the centering ball, it is a must? Also make sure you put 1 grease fitting in each slip shaft and lube them good.
Old Sep 29, 2012 | 01:38 PM
dr. mordo's Avatar
Well, the metal hammer worked. Thanks!
I do plan to replace the centering ball, and I have a question.
On the linked how-to he says "If it has been upgraded to the 1310 series which centering kit it takes will depend on whether the center head is greaseable or not."
Mine appears to be the 1310. There isn't a grease fitting on the outside of the centering head. Does that mean it isn't greaseable?
Any idea what the 1310 part number is for the centering ball?
Old Sep 29, 2012 | 01:52 PM
Spencerfitch's Avatar
1310 Is a larger u joint you only have this if its a. Aftermarket driveshaft.stock centering ball is 617 the 1310 shaft should use 618 it's the exact same just a different dust cap
Old Sep 29, 2012 | 02:24 PM
dr. mordo's Avatar
Well, I just called every parts store in town, and they can't even order the 618. Does anyone have the neapco part number?
Old Sep 29, 2012 | 06:38 PM
dr. mordo's Avatar
Turns out I was wrong - it is a greaseable centering ball.
Also, after much research it turns out the part number is Precision/Moog 612 or Neapco 7-0081 (without the NG). I still can't find them locally, so I'll have to order one.
Thanks for the help!
Old Sep 30, 2012 | 10:17 AM
diggerod's Avatar
I'm getting ready to change out my u-joints in the front shaft next weekend, what are you guys referring to as the centering ball? Thanks
Old Sep 30, 2012 | 01:26 PM
dr. mordo's Avatar
Pics of it here:
https://landroverforums.com/forum/di...ld-done-30781/
It keeps the double u-joint from flopping around.
Old Sep 30, 2012 | 06:38 PM
diggerod's Avatar
Thanks Dr. Mordo, I did not know that centering ball was even in there. Thanks again
