can't get grease out of the front driveshaft
Old Dec 15, 2013 | 12:48 PM
FlyingZebra34's Avatar
Default can't get grease out of the front driveshaft
Hey all I rebuilt my driveshaft recently and have it installed fine but I can't seem to get grease out of all 4 seals on any of them. I've blown through a few tubes now and I can't get it to work.
Old Dec 15, 2013 | 03:09 PM
Colorado David's Avatar
How long ago did you rebuild? Is the grease just squeezing out around the zerk? If you can't move grease through the u-joint, it is toast. As grease gets older, it gets cooked by the heat from the cat. Keeping the grease fresh keeps it working. Once it's solid from the heat it loses it lubricity.
Old Dec 15, 2013 | 08:22 PM
I rebuilt it earlier this week. Its only coming out of 1 end on each of the 3 new joints
Old Dec 15, 2013 | 08:53 PM
pinkytoe69's Avatar
After redoing mine, I could only get grease out of 2. I ziptied a scrap of paper towel around the joint with the most discharge, and was then able to get machine grease out of the other two.
I then drove it around for a couple hundred miles. After that, the grease came pretty easily out of all 4.
Old Dec 15, 2013 | 09:40 PM
Thanks pinky! I'll give that a try.
Old Dec 15, 2013 | 10:48 PM
Okay. Well that's a different story then. If it had been six months and no grease coming through I say it was cooked.
Old Dec 15, 2013 | 10:52 PM
pinkytoe69's Avatar
You might be able to just go for a 20 mile drive...just something to limber the joints a little.
Old Dec 16, 2013 | 08:19 AM
04duxlr's Avatar
Sometimes hitting the yokes with a hammer will loosen up the caps enough to get grease out of the caps, but if the zip-tie and paper towel approach works it sounds like a good way to go.
Old Dec 16, 2013 | 08:54 AM
dusty1's Avatar
yep, hammertime always worky for me
Old Dec 16, 2013 | 09:47 AM
I guess I'll have to bust out my official land rover adjustment tool
