Can't get low-speed temps down.
Old Oct 8, 2019 | 06:10 PM
Discorama's Avatar
Originally Posted by cvhyatt
Ironically, if I have the AC on full blast while driving on the highway, I can get the temps down to 197.
Looks like your engine fan is very lazy.
Old Oct 8, 2019 | 06:37 PM
Extinct's Avatar
I know I sound like a broken record on this, but the bleeding issues and high temps are related to the factory thermostat/flow system. Go to the bypass stat and your issues will go away. Don't believe me, do a $5 test. Buy a hose repair kit at advance and put a bushing in place of the factory stat, put the top radiator hose directly to the manifold outlet. Your problems will be magically gone. I could be wrong however, I've only had 12 D2's.
Old Oct 8, 2019 | 06:55 PM
cvhyatt's Avatar
Hey Extinct - I hear ya but how come some of these work with the factory set up? I am all for doing performance mods but I also don't want to mask the real cause of the issue...
Old Oct 8, 2019 | 06:56 PM
cvhyatt's Avatar
Yep - I am thinking it is time to convert to electric.
Old Oct 9, 2019 | 05:08 AM
Extinct's Avatar
Do the $5 test and you can easily see if it is a bad fan clutch, plugged radiator, or the thermostat. The problem with the factory thermostats is it can fail in two different modes. Mode 1 it does not open and engine overheats quickly, mode two it allows the coolant to bypass the radiator and it overheats slowly. With the bypass stat you eliminate mode 2 because the bypass hose is gone and the Chevy stats are more reliable with respect to mode 1.
Old Oct 9, 2019 | 07:53 AM
cvhyatt's Avatar
Bleeding has not resolved my issues but there was significant air in the system.
As much as I would love to convert to electric, it’s more than I want to take on at this time. I ordered the Hayden 6352 off rockauto and will swap it out hopefully this weekend. Looks fairly straightforward. Stay tuned.
Old Oct 10, 2019 | 04:32 AM
shanechevelle's Avatar
Try parking it on a hill, get that front end up.
I dont do anything but park on a hill, let it run, open that bleeder. I also squeeze my hoses.
New parts always help.
Green FRESH coolant. Coolant does go bad.
Old Oct 10, 2019 | 12:02 PM
Ben Matheson's Avatar
If there was air in the system its unlikely you got it all out in 1 day.. check it 3 days in a row and you might be surprised
Old Oct 10, 2019 | 09:08 PM
Jason_B's Avatar
I think the 2004 has an integrated fan and clutch so I don't think the HD clutch is plug and play but I am also interested in this upgrade so please let me know how it goes.
Old Oct 10, 2019 | 09:31 PM
cvhyatt's Avatar
I have been topping off for the past couple of days. Still no change. Going to replace the fan tomorrow. I will pull the stat and test it as well.
