Can't shift into L...
I am not 100% sure on this one but I will give it a try. If I am wrong someone will call me out right away.
Your shift linkage is probably frozen from not being used often enough. You have to get under the truck and grease it and play with it for a while. I read once on this forum that you should shift it into L every once in a while to prevent it from freezing.
![Wink](https://landroverforums.com/forum/images/smilies/Uh2vXQr.png)
x2 on what buick215 said.
I'd try soaking the linkage in PB Blaster from under the truck...including the cable that runs from the shifter to the transfer case. The cable is a solid metal shaft that runs through a plastic/rubber/braided metal jacket, so I would image that if it isn't lubed, this could be a big part of the issue too.
![](http://www.roverparts.com/product/img/Icn/ftc3283g.jpg)
When you say remove it, does that mean bypassing it? Or by removing it do I lose 4 Lo?
