Can't shift out of park
Old May 21, 2021 | 10:52 PM
Colorado David's Avatar
Default Can't shift out of park
I was in the hospital for a week and when I got home, my Disco II started right up, but it won't shift out of park. I have a vague recollection of other people discussing the XYZ switch. Could that be it?
Old May 21, 2021 | 11:58 PM
Harvlr's Avatar
Dumb question but are you stepping on the brake pedal to activate the park lock out of the way?
Old May 22, 2021 | 12:07 AM
Yes. Stepping on brake.
Old May 22, 2021 | 12:17 AM
Dave03S's Avatar
Are the brake lights coming on? Brake light switch is the usual suspect.
Old May 22, 2021 | 04:47 AM
mollusc's Avatar
Mine does this sometimes. XYZ switch needs adjustment. Is the light beside P lighting up on the bezel and P appearing on the dash? If not, give the lever a bit of a whack forwards to get a final fraction of a millimetre and hopefully they will light. That should allow you to move out of park and start the truck in neutral.
The other option is the brake light switch needing adjustment, as Dave said.
Old May 22, 2021 | 10:14 AM
The Deputy's Avatar
Yeah, chack brake lights...if not coming on...most likely switch. You can pull the surround up from around shifter **** and reach in with a pocket kinfe to release lock solenoid.
Old May 22, 2021 | 04:57 PM
No brakes lights so I guess that narrows it down pretty well. Thank you.
Old May 22, 2021 | 05:40 PM
mln01's Avatar
I don't know just where between the Arkansas and the Platte you are, but if there is an AutoZone nearby the switch that comes in the Duralast box is genuine Land Rover (and marked such). Unfortunately the price I'm seeing today at the AutoZone web site is about $10 more than what I paid a few years ago. Be sure to get the version pictured at the page linked below. It's the updated version, which presumably doesn't have the failure rate of the original design. It's not difficult to change the switch, just a little awkward.
https://www.autozone.com/electrical-...410/363568_0_0
Old May 22, 2021 | 07:03 PM
The Deputy's Avatar
Yes, the newer version is the way to go. Just read directions thoroughly, since you have to install switch, depress brake pedal and turn swich another quarter turn to finish installation. Plug is the same, but has pigtail.
Old May 22, 2021 | 07:53 PM
Thank you all very much.
NMAZE
Jun 21, 2018 06:44 PM
bigred2929
Aug 6, 2015 09:58 PM
cybercop
Sep 25, 2014 10:27 PM
jeffmcdaniel
Feb 15, 2014 02:31 PM
bballjames
Aug 29, 2013 12:25 PM
