Can't shift out of park
Old Nov 23, 2018 | 02:29 PM
Russ Collins's Avatar
Angry Can't shift out of park
Hi Guys, This is my first post. I just bought a 2000 Discovery II and I have an issue. everything was fine but then all the sudden I cant shift the car out of park and the differential Lock indicator is showing. Can anyone help?
Old Nov 23, 2018 | 03:28 PM
tcr6v1's Avatar
Pull the PRND12 bezel carefully up and you'll see the shift lock on the left side. Push that in and you'll be able to get it out of park in the mean time while you diagnose
Old Nov 23, 2018 | 03:55 PM
mln01's Avatar
Welcome to the forum, Russ. The two symptoms are likely unrelated. A common cause of not being able to shift out of Park is a faulty brake light switch. Check to see if the brake lights come on when you press on the brake pedal with the ignition switch in Position 2. If the brake lights don't come on replace the brake light switch. Whether or not they come on please report back here to either diagnose the shifting out of Park problem or to diagnose why the center differential light is on.
bigred2929
Aug 6, 2015 10:00 PM
FrauBurau
Sep 27, 2014 09:58 PM
FJL
Aug 20, 2009 01:42 PM
FJL
Aug 20, 2009 12:10 PM
johnny
Aug 29, 2007 08:26 PM
