Card stuck in a bicycle spoke noise
Old Oct 23, 2021 | 05:10 AM
Invictus's Avatar
Default Card stuck in a bicycle spoke noise
Hello everyone. My 04’ Disco II is making a flapping noise while accelerating to speeds above 10kmh. The closest thing I could compare the noise to is the noise produced by a playing card stuck in a bicycle spoke. The noise gets louder as I go faster. In addition to the flapping noise, I can feel the truck rumbling slightly.
A different noise is produced when coasting and not accelerating. The noise is a rapid click. My best guess is a drive train or transfer case issue, as the flapping/clicking is not heard while at a stop. I have some 75w-90 gear oil on order as the transfer case fluid is quite low, though I am not confident that topping off the oil will remove the noise. Any suggestions would be greatly appreciated!
Old Oct 23, 2021 | 06:39 AM
zski128's Avatar
Check the front driveshaft
Old Oct 23, 2021 | 06:41 AM
Invictus's Avatar
The front drive shaft has new u-joints, installed two months ago. This problem began about a month after the u-joints were replaced.
Old Oct 23, 2021 | 09:35 AM
disco96sd's Avatar
check that t-case fluid level - when one is about to let go they make a sort of "catching" sound and it will impede the movement of the landy off and on until it locks up
Old Oct 23, 2021 | 01:40 PM
Brandon318's Avatar
Check the engine fan and that it's not basically doing exactly what you're describing.
Old Oct 23, 2021 | 05:22 PM
Invictus's Avatar
Thank you for the suggestion. The noise is not present while at a stop. But I checked just to be sure there were no objects stuck in the fan.
Old Oct 23, 2021 | 06:00 PM
PickleRick's Avatar
Was the center bearing replaced with the u joints? It can make the same noise. Pull shaft and spin/flex by hand on the DC side to see if you hear clicking.
Old Oct 23, 2021 | 06:13 PM
Invictus's Avatar
No, the center bearing was not replaced.
Should the front driveshaft have a little left/right play when hand-rotating the shaft with the wheels on the ground?
Old Oct 23, 2021 | 06:27 PM
PickleRick's Avatar
The spring loaded center bearing takes out the slop between the joints. I just went through this on a 99. Even on the rig I could make the shaft with new joints move.
edit: you'll have some spin slop due to some designed drive line play but you should have zero play in drive shaft joints..
Old Nov 2, 2021 | 09:03 PM
Invictus's Avatar
I replaced the drive shaft with a pre-built hardened drive shaft and the noise is still there. Any suggestions? I’m stumped.
