Castrol oil
Castrol oil
Hi guys,
My independent rover mechanic used this motor oil in my 300TDi D1.
http://www.castrol.com/castrol/secti...tentId=7018628
Is this any good? Should I shift to RP or Mobil 1 next oil change.
Since I change my oil and filter every 3,000 miles. Does it matter?
RE: Castrol oil
Thats good to hear
Yes Mike its a 300 TDi Diesel engine.
Ill change it after 3000 miles and shift to its synthetic counterpart.
Thing is, I don't think they supply K&N and Mobil filters here they always use the Coopers brand. [:@]
Can I still go 5000 miles with the Coopers brand?
I use the D1 for office work only, no off-roading, no trailers etc.
OT: Is the gear oil the same in the t-case and differentials?
Is differentials the same as front and rear axle gears?
I saw in the car shop last night Royal Purple Max-Gear 75W-90 is this what I need to buy?
RE: Castrol oil
I love castrol synthetic, it's all I use. I go back and forth between full synthetic and the blend that Mike mentioned.
The oil change is more based on oil and not filter. I'd order a few mobile 1 or K and N online have them shipped, but that's up to you.
Gear oil for t-case and diffs: Yes, same weight. For your driving, 75w-90 is perfect and be sure to use all synthetic oils. For people who do more off roading and put more wear on the t-case and diffs you can using a thicker weight, but for daily driving the above is good.
RE: Castrol oil
ORIGINAL: DiscoRom
Thats good to hear
Thats good to hear
The Coopers brand oil filter is just fine. Yes you can still go every 5,000 miles with that oil filter.
I would use 75w-140 gear lube.
And yes, the front and rear diff and the t-case use the same fluid.
I do not know if you can even get a K&N or Mobil 1 oil filter for a 300TDI.
disco12
03-07-2006 01:10 AM
