Castrol only?
Old Feb 7, 2009 | 09:49 PM
DiscoRom's Avatar
Default Castrol only?
Planning to bleed the brakes soon. But the Rave CD (or some site) says to use Castrol brake fluid only!
I went to the local stores here, no Castrol just Prestone and other DOT4 brake fluid.
Has anyone tried other brands?
Old Feb 7, 2009 | 09:57 PM
Default RE: Castrol only?
We all use other brands, I used Valvoline Snythetic DOT4, just make sure that it is DOT4 and that it says "low moisture" on the bottle.
Old Feb 7, 2009 | 10:07 PM
Camdisco24's Avatar
To add to spike's post... Basicallyall DOT 4 brake fluids are pretty much made to the same standards set by the manufactures, with the exception of of a few out there that make a pure synthetic brake fluid like Vavolines synthetic brake fluid as spike mentioned. So as long asyou use some form ofDOT4 you should be set, just go with a brand you trust.
Old Feb 7, 2009 | 11:29 PM
avking's Avatar
Atlantic British has the Castrol if that is what you want.
Old Feb 8, 2009 | 08:23 AM
I have been using Vavoline's synthetic for year and swear by it. Just go buy 3 pints and get started.
Old Feb 8, 2009 | 09:13 AM
DiscoRom's Avatar
Ok will get any DOT4 synthetic preferably with low moisture effect will do.
Why would LR endorse Castrol only? They seem adamant about it. Go figure.
Anyway, the experiences with other brands trumps LR's recommendation.
Thanks.
Old Feb 8, 2009 | 12:42 PM
Well LR recommends it because Castrol is a British company, that is the only reason that I can think of.
Castrol 20w-50 is the motor oil used in the Queen Mary.
So any English car or truck will recommend Castrol oils and lubes.
Just like GM and Ford recommend their oils and lubes.
And if I remember right the new LR's even say to use Castrol motor oil on the oil filler cap.
the420star
Aug 1, 2015 06:51 AM
NickAdams
Nov 24, 2012 06:42 PM
DiscoRom
Jan 21, 2009 04:02 PM
Rovercountry
Mar 22, 2006 03:38 PM
Meyer
May 24, 2005 01:32 AM
