CATALYTIC CONVERTER
Old May 9, 2007 | 12:18 AM
suveer's Avatar
Default CATALYTIC CONVERTER
Hi All
I have a 1997 300tdi discovery which has 230 000km on the odo. I am thinking of removing the catalytic converter as i'm sure it is now old and probably blocking the exhaust gases from blowing out properly. Can i do without it by just connecting a straight pipe.
many thanks
Old May 9, 2007 | 07:21 AM
Default RE: CATALYTIC CONVERTER
Where do you live?
Mike
Old May 11, 2007 | 12:53 AM
suveer's Avatar
i live in South AFrica. There is no strict emmission control regulations.
Old May 11, 2007 | 08:25 AM
As long as there are no emission sensors attached to it or behind it then I would think this would help your exhaust flow better, if your cat is plugged. You can also run a few bottles of additive thru your fuel system which when taken out and driven hard, will clean up the cat also.
Mike
Old Jun 14, 2007 | 02:50 PM
bulldoggergal's Avatar
Will the additive work if I already know there are two holes?that a plugged up (according to mechanic).
We tried that...but I guess we are beyond that point...time to replace?
How much should we expect to pay for a new Cat for a 98 Discovery? Our repair told us the cost is 2k just for the Cat...plus 3 hours labor. Is that about right?
Old Jun 14, 2007 | 04:40 PM
I have no idea what a diesel cat will sell for, but as far as the installation goes, something under an hour labor.
Mike
Old Jun 14, 2007 | 05:36 PM
It's not a diesel...any idea of cost? What is your opinion of buying the "used" or "rebuilt" cats on the internet? From a parts dealer, not individual.
I guess maybe I should get a second opinion on the labor cost...3 vs 1 is a big difference.
This is one problem I'm not familiar with...I thought we had a case of bad gas.
Thanks so much for the advice!
Old Jun 14, 2007 | 06:00 PM
You can get good prices on new replacement cats on-line, like at, http://www.completeexhaust.com/produ...roducts_id=184.
Mike
Old Jun 14, 2007 | 06:21 PM
geoman's Avatar
I wouldn't recommend buying a used CAT (actually illegal in some places to install a used Cat), but instead would encourage you to have a qualified shop cut-off the old ones (you have two on the Y-pipe) and weld in a good quality hi-flow replacement unitas manufactured by Magnaflow(Carsounds), Catco, or D.E.C.
These manufacturers all make a "universal" style convertor, where you just have to match up the inlet and outlet pipe diameters (and offset--if required). Stay away from the cheap universal Cats you see listed on-line with no country of origin or brand name offered. The metal-substrate types flow much better than what was originally on your vehicle and will most likely give youbetter fuel mileage and a little better acceleration.
Ceramic substrate Cats (that will still flow better than O.E.)from these manufacturers can be bought for $50-75USD. Add your local labor charge for installation and you are good to go
Of course-- all I have said here does not apply to those readers living in California. Only Cats that meet the California certifications are legalas replacement units here.
regards,
Geoman
www.eurotekapg.com
Old Jun 14, 2007 | 07:35 PM
Excellent. Thank you. I was thinking that $2500.00 was a little steep...not to mention unaffordable!
