Cats maybe? And not the furry kind.
Old Aug 9, 2014 | 07:46 PM
parke's Avatar
Default Cats maybe? And not the furry kind.
Ladies, Gentlemen, and Children of ALL ages, do I have a treat for you. My 2000 Disco is definitely not purring, in fact it's running like total A$$. It is running very rough, at idle seems to be at half power during acceleration, and it also seems to be leaking exhaust around the seams of both cats. Check engine light is on showing the following codes:
P0304 cylinder 4 misfire
P0302 cylinder 2 misfire
P1300 no idea what that is
P1884 multiple definitions
P0300 random misfire
I am leaning toward replacing the cats and O2 sensors, just wanted the opinions of this esteemed crowd first. Thanks any help is much appreciated!!
Old Aug 10, 2014 | 06:43 AM
drowssap's Avatar
cats and O2 sensors would not be the first place I would look, neither one will cause a misfire.
"I" would look for an ignition problem (plugs wires) and whenever I see multiple misfires side by side I have to ask How's your coolant level?
Old Aug 10, 2014 | 03:21 PM
parke's Avatar
Coolant level is good, oil tests were all clear. I run Chevron 10/30 Supreme in spring/summer and chevron 5/30 Supreme in fall/winter, with Baldwin filters all around. Due to my profession I have access to free fluid sample testing and test oil every 3000 mi. The exhaust leak at the cats and (did I mention?) the weak/sputtering exhaust at the tailpipe had me leaning toward the cats.
I thought that I had read that an O2 sensor reading not enough fuel, due to a clogged cat, could cause the ECM to dump more fuel into the cylinder and therefore cause a misfire due to a cylinder being too wet? Maybe I misread that.
Do you know if there is a way to test a coil while it's off, so that I don't have to just throw parts at this and then tear down and build up the intake over and over again. I figure that cant be good for the upper intake gasket. Mind you I could use new valve cover gaskets, so this could be a great excuse!
Old Aug 11, 2014 | 07:23 AM
drowssap's Avatar
i would start by moving the wires and plugs and see if the faults follow
Old Aug 11, 2014 | 07:49 PM
parke's Avatar
I will. Thanks!
Old Aug 13, 2014 | 01:38 AM
Fallstaff's Avatar
This is from an absolute unqualified position, but it's where my mind went immediately: any chance something is just blocking your exhaust somewhere after the cats? Like something crawled up there to die (hate to say it, but like the furry kind).
Old Aug 13, 2014 | 05:41 AM
parke's Avatar
Checked the plugs and wires last night, did it at night so that I could just remove the spark plug reattach the plug wire and start the truck to tell if there was spark. Everything firing the way it should. And no, I hadn't entertained the thought of something furry crawling into my exhaust and dying. But, you never know.
Old Aug 25, 2014 | 10:00 PM
parke's Avatar
Default New cats, problem solved!!
I figured, screw it and replaced both cats with universals. After a little exhaust tubing fabrication I got the both to fit very well. Cleared my codes and after 3 days of driving no more codes!! Thanks to everyone for your help!!
Old Aug 26, 2014 | 09:13 PM
04duxlr's Avatar
Glad to hear it is running well but what clogged them in the first place? Usually that is due to them overheating and melting from running lean or they get fouled from the truck running too rich. Just hate to see them get trashed again. By the way, many D2 cats bring good money when recycled so make sure you take them to a decent scrap yard. Might get a enough money to cover the next repair! Oh and regarding the unknown code a P1300 is Catalyst damaging level of misfire on more than one cylinder.
carid
Member Group And Special Buys
Apr 17, 2015 04:41 AM
gmscando
Mar 28, 2011 11:51 PM
Timpala`
Feb 2, 2010 05:44 PM
Suede
May 16, 2009 05:32 PM
lifewithoutanet
Dec 1, 2008 11:51 AM
