Caught drive shaft just in time, but need help!
I have a 2004 Discovery 2. Bought it used. Felt some vibration and started to hear "chirping", so parked it and I ordered a new drive shaft. Got the old shaft off and saw that joints were starting to come apart in the rear. Seriously caught it just in time. When I tried to install the new shaft, I can't get it to align properly. If I bolt in the front four studs and bolts, I am then a couple of millimeters out of alignment for the rear four studs. In looking at the old shaft that was about to go, there is some play in the rear joints due the damage at the joint and perhaps this let the rear fitting get slightly out of alignment?. There is a little play at either end, but not enough to allow me to properly align the studs.
What to do next?
I do have the locking differential feature and can lock the differentials and take it in to a shop. But what are my alternatives before brining it in?
What to do next?
Just ensure you buy a new driveshaft with greasing zerks in every UJ either in the cruciform or on each UJ head. You've been especially lucky on this one so ensure you pump in plenty of grease. Under normal circumstances it could have cost you a transmission casing and a lot of hassle so send Santa a nice card eh
IB Jason
Range Rover Evoque
03-24-2015 02:27 PM
br0keit
12-14-2013 01:01 PM
luxury1
01-25-2009 03:08 PM
