CD changer to ipod swap
Old Nov 15, 2011 | 10:09 PM
kentuckyroverman's Avatar
5th Gear
Default CD changer to ipod swap
So I recently got an Iphone and i would like to use it instead of my (non functioning) CD changer. I was hoping I had the alpine 6 pin connector so I can just order an ebay plug which converts it to a set of RCA cable, unfortunatly I have the 10 pin. So ive looked at the rover wiring diagram (which here it is if anyone wants it http://www.discovery2.co.uk/pdf_file...grams_03MY.pdf ) and I was unable to track down the wiring for the cd changer. Does anyone know the color codes for that 10 pin adapter, I would think that I can just splice in the red and white wires to the respective colors, but I want to find that out before I do. I plan on going to town on it with a continuity tester soon but I thought I might ask if anyone has any prior knowledge.
P.S. I am searching for a lift and some tires if anyone has a set they are willing to part with.
2001 LR D2
Cold Air Intake
ABS Module SVS rewire
Old Jul 13, 2013 | 09:19 PM
bdweix's Avatar
4th Gear
Did you ever find a solution for this? I have encountered the same problem.
Old Jul 14, 2013 | 01:22 AM
Street Wolf's Avatar
USA | GB 4x4 RADIOS
Old Jul 16, 2013 | 07:27 AM
drowssap's Avatar
$39.00 here you go Land Range Rover Interface Module Cable iPod iPhone 3 5mm Smart Phone Aux Input | eBay
this goes under the passenger seat in place of the CD then just run the cables up between the seat and the console.
Old Jul 17, 2013 | 08:39 AM
eitydeuce's Avatar
That's what I have been looking for! Thanks!
Old Jul 17, 2013 | 08:41 AM
drowssap's Avatar
your welcome
Old Jul 17, 2013 | 11:59 AM
ukwildcats's Avatar
Will this work on the 2001 D2 with CD Changer -- I am going to look at my CD Changer Electrical Connection tonight when I get home.
While sending my Radio to someone is doable -- just do not want to spend that kind of money when I have other things to spend it on such as Drive Shaft repair/replacement, new Front Bumper, etc.
UK
Old Jul 17, 2013 | 02:13 PM
ShaggySE7's Avatar
I have one of those cassete adapters that I plug my phone into. works like a champ. I'm in a 99. Not sure if yours has a cassette but it works for me.
2001 LR D2
Cold Air Intake
Old Jul 17, 2013 | 02:58 PM
ukwildcats's Avatar
I tried the Cassette adapter -- did not work for me, could be that the Cassette in the radio is non functioning
I currently have the FM Transmitter from (Scotche) and it works ok
-- except it needs a battery, which could be a problem
-- and you tune to a particular channel on the transmitter, and could be a problem on the road
We do not use CD's much anymore, everyone in the family has gone digital -- could burn CD's for music but if I can fine an adapter to plug a IPod Touch/IPhone into the system that would be great but not going to spend alot for this when I have mechanical things to fix first.
UK
Old Aug 25, 2013 | 02:38 PM
joejacintoaz's Avatar
ISO: LAND RANGE ROVER INTERFACE MODULE CABLE iPOD iPHONE 3.5MM SMART PHONE AUX INPUT....unable to find one online....both fleabay, amazon and banggood.com
